AVS › AVS Forum › Audio › DIY Speakers and Subs › Exodus Subs - Resurrection
Exodus Subs - Resurrection - Page 3
post #61 of 70
There's always this as an alternative to the Anarchy :P
http://gr-research.com/m165xwoofer.aspx
post #62 of 70
Sure its got the xmax, but the lack of inductance control does not make it a Anarchy substitute.
post #63 of 70
Originally Posted by N8DOGG View Post
We want a 28" sub with 80mm of 1 way stroke, a 8 inch VC, Argo style super Neo motor, cone made from a spiders silk, 3 replaceable surrounds and Oh ya, it has to way less than 10 lbs and be able to output 150dB's at 100 yards..... ok GO!!! tongue.gif
Geez bro, is that it?
post #64 of 70
That sucks! I've been dreaming about designing a 3-way that uses 2 Exodus Anarchys up to about 250 Hz or so for a crazy-good low end extension and punch. That idea is a little cost prohibitive and now the Anarchy (which is not discounted, BTW) is going away. Say it isn't so!
post #65 of 70
I have a design for the Anarchy using two per cabinet, SS 10F mid, and a .75" ring radiator per cab if anyone is interested. It has a full 6db of baffle step though, I'll be working on one with less BSC soon.
post #66 of 70
Sounds really interesting, is it a Vifa ring radiator or the SS discovery?
post #67 of 70
Sounds like a nice sub-free tower speaker for the living room. What made you choose the mid you did?
post #68 of 70
.75" SS Illuminator.
Wide dispersion, low distortion, and it is very easy to work with.
FYI, the Anarchy is on sale for $50 this AM.
post #69 of 70
Face, you have a PM.
david
post #70 of 70
Someone tell Eric. Maybe he can buy up a bunch and sell the anarchy tapped horn flat pack with a driver?
