In my basement I have a gang of recessed lights which I'm assuming, but will confirm, total less than 600 watts. They are on a three way switch currently, with two wall plates on opposite ends of the room.
Can I simply swap one of the switches with this Lutron pack and insert a remote controlled dimmer into the mix, with the other switch continuing to simply turn the whole set off and on to full power?
http://www.amazon.com/Lutron-MRF2-600MTHW-WH-Multi-Location-Controller-Wallplate/dp/B003U8Y9QA/ref=sr_1_2?ie=UTF8&qid=1355845415&sr=8-2&keywords=lutron+remote+control+dimmer
Is there a different configuration that would be best for me?
