Hey guys
two questions here
1) does the bottom of this projector get very hot ? I think the vents are just on the front if i am not mistaking but if i were to place this on a wooden shelf, i do not want the wood getting too hot if possible.
2) I was hoping to side wall mount this guy either by creating some kind of shelf that supports its 20-21 lb, or if there are any side wall mounts that would work well here... i am trying to just go the cheap route so if i need to just make some kind of shelf i can do that, but i was curious what kind of side mounts or any solutions that may be used here. I searched around but only found really old forum posts about this from 07
Any help would be great. Thanks guys!
two questions here
