Hi,
I should start off saying that I have been reading through the theatre forum on construction and sound proofing for about a year and half now while I have been slowly working on my dedicated theatre. First of all I have to say that I have had many ideas from what many of the members have done along with learning much about design and sound proofing. There are individuals on here like Ted White and Denis Erskine (along with many others) who have greatly educated me on sound proofing by their many posts and I greatly appreciate their knowledge. Especially since I originally thought sound proofing was just a matter of throwing some insulation up in the rafters, I can tell you that has certainly changed. So I am now getting to the point to where construction is moving along and I would like to make sure that I am doing everything correct. I'll explain what I am doing, what I have done and what my objectives are.
My main objective is to keep the sound from going up through the ceiling, as the bedrooms are just above it.
My plans so far is to use 5/8" DD GG along with sound clips and insulation for the ceiling. I have pot lights which will be installed but they are in boxes that I built from the 5/8" DD and GG to keep in the sound and they will be sitting on top of the ceiling. I will also be using the recessed technique in the ceiling to install that sound clips as I have an older house and only have a 7 1/2 foot ceiling. As for the walls I was thinking of just putting in one sheet of 5/8" dry wall along with resilient channel. I am aware of the chance of shorting out the resilient channel so I will be the only one installing the dry wall. I don't trust any one to understand why it is so important to not short it out plus I am doing most of the work myself. All the electrical outlets will have putty around them to keep the sound in. The walls that are along the foundation of the house are 1.5 inches from the wall but have a 1 inch thick piece of styrofoam insulation between the wall and stud. This is because my basement can get very cold and I have also removed the HVAC from the room. The walls are 16" on centre with R14 Roxul insulation in between them. I will also be putting in double French doors (I know they are not great for sound proofing) but they will not sit right below the bedrooms more in the area of the hallway that is upstairs.
Like I said my main goal is to keep sound from going straight up through to the bedroom. I figure with the DD GG and sound clips that the ceiling will no be the weak point. My main concern is about flanking noise. I read that keeping the walls an inch or more from the foundation walls will mechanically separate the two and make it harder for sound to travel but I also wonder about the foam that I put behind it and where they are nailed into the top will cause flanking. I am also wondering if the use of resilient channel is needed to stop any flanking. I am not so worried about sound getting out of the room in to the basement as I am more concerned about it flanking and getting into the bedrooms above. That is why I am planning to use resilient channel and only a sheet of dry wall.
I should also mention that I have a tele-post that I would like to remove. Don't worry I won't just casually remove it, I will bring in a structural engineer and have the engineer figure out a way to compensate for the removal. I will also pull a permit from the city to have it done and inspected. But then again I might not have it removed as it is still up in the air.
I also have a 5x3 foot window in the basement which might need some consideration.
I will post pictures of what I am doing and have some more questions and would greatly appreciate any input.
Aaron.
Aaron.
