Originally Posted by
brian6751
looks great to me. rest of them will be easy now
Thanks Brian! I'm thinking I spent far too long on making the bracing look nice, haha.
Before roundovers - I didn't bother getting the template super smooth, but they turned out decent.
After:
First box assembly started:
This box needs:
-Flush trim to clean up Inner/outer baffle after my rough cuts with the jigsaw
-Install port and port bracing
-Install vertical bracing
-Install top
-Build/install crossover
-Install rear speakon terminal and wires
-Sand/Fill
-Paint
-Install woofer/waveguide/driver
The rest of the boxes should go super fast now that I have the order down and all the pieces are fitted.
Edited by Gorilla83 - 1/13/13 at 1:14pm
