AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › If I don't have $1000 will the 50UT50 sufice for $699?
post #1 of 18
LG 47LS4500 $579
U50 $599
UT $699
ST $999
GT $1139
I really want the ST but bahhh money
What is the input lag difference on these and is the U50 just a UT without 3D or will the UT perform better?
post #2 of 18
LG is a no go. The UT50 is extremely good especially at that price.
post #3 of 18
You sure? have you seen them?
Are there ANY LCD's that can compare? Samsing UNEH5000, 5300F, 6000, 6030? Panny E50, ET50, E5? LG LM4600, 4700, 5800, 6200 and the LS5700 I don't get all the differences? I can't seem to find a decent one till its over $1000
Edited by ScaryFatKidGT - 12/27/12 at 11:46pm
post #4 of 18
I really need help and don't know what to get, Id rather have a better looking 42" than a 46 or 50"
When I look at LCD's I don't care they are not the ST50 but with the UT50 I just feel like the ST or GT50 would be so much better
post #5 of 18
The 50UT50 is very nice, especially at that price. Shares many specs and features of the ST and GT, but lacks the extended custom controls. And the screen is a bit glossy, so be mindful of glare. But still very nice pic quality and a better choice than Samsung E530 and LG 5500/6500.
post #6 of 18
If you can afford it, go with the ST50. From reading reviews, the ST50 has noticeably better bright room performance than the UT series, but if you have a light controlled room, the UT series is no slouch, especially at it's price point.
post #7 of 18
It is? cuz I want just going to ask about the 530 and 550, is the 530 or 550 any brghter?
the 450 is only 730 right?
Whats the difference from the U to UT? Just no 3D?
So basically id have to have my lights off all the time and watch in the dark?
Also looking at the Toshiba 47L5200U, sorta replaced the LG
Edited by ScaryFatKidGT - 12/28/12 at 1:26pm
post #8 of 18
I'm sure the UT50 will more than suffice for $699 if you can control the light in your room. If you've got a very bright room you might want LCD/LED.
http://reviews.cnet.com/best-high-definition-tvs/
post #9 of 18
I actually have a fairly dim room in the basement, I just don't want to have to be in the dark.
I have read every 2012 Cnet TV review like twice and cross referenced them with other sites like PCMAG and others so I'm pretty burnt out, I just want to get something. I can't believe how many TV's they just toss aside as crap IQ even though most of them are best sellers in stores.
The only LCD I have seem to narrowed it down to is the Toshiba 47L5200U or maybe the Sony 42" 440 but I would like a 46"
post #10 of 18
Just shows the average consumer is not very discerning
post #11 of 18
Best sellers in stores are normally the cheap stuff. Keep in mind the likes of Wall mart normally only stock the cheapest models. The UT50 is a bargain at this price and much better than any other model mentioned here. Only high-end LCDs can match the plasma picture and even so , very few of them.
post #12 of 18
I have a Panasonic U50 in a basement with only 2 windows off to the sides of the tv, so no direct sunlight enters the room, but even on a sunny afternoon with the shades up, i find the U50 to still show a nice picture. The blacks do become a bit grey, but it's not like the picture becomes unwatchable.
post #13 of 18
I mean like the Sony EX440 and Samsung LED's, LG and Vizio not like cheapos like Insignia or Westinghouse.
So U vs UT for $100 please?
post #14 of 18
Actually how does the UT50 compare to the S30 and ST30 sense I have seen those. If its brighter than the S30 I should be fine my friend has it and its great.
post #15 of 18
Well I got my UT50, so will the ST50 be brighter in a dark room? or will the blacks just be blacker in a dark room? It's pretty much what I was afraid of, lights on=gray almost like my LCD but more uniform, lights off=ink black
Also in my custom settings it kinda looks to bright and washed out but brightness and sharpness don't seem to do much? and lowering the contrast lowers the brightness
Cinema mode is the most accurate? It looks to soft with whites being off white and slightly to warm colors then vivid just looks awful ha
post #16 of 18
Cinema mode should be the best out of the box. Check the High Def Junkies website to see whether D-Nice has posted his recommended settings for the UT50. The UT50 and ST50 should look very similar in a dark room. In a bright room is where the ST50 will look better.
post #17 of 18
Is there other hidden adjustment? Like even with stuff set the same the modes look different. Cinema is actually not bad once you get it off warm 2 to neutral or warm 1.
Edited by ScaryFatKidGT - 12/30/12 at 11:07pm
post #18 of 18
Your best bet for settings is to check out the dedicated thread on this display, and search High Def Junkies web site for D-Nice's recommended settings (he didn't post them here at AVS).
