Ok, so, not something that audiophiles can really sink your teeth into, but I would appreciate any assistance you can offer.
Current Setup:
Fronts/Center - Polk RM201 x 3
Surrounds - Polk RM101s x 2
Subwoofer - Cambridge Soundworks Basscube 10s (Deceased)
Reciever - Onkyo TX-SR605
Im looking for something that has at least as much power (75w 10" downfiring active sub). So 100w is probably suitable. Smallish room. 80% Movies/TV and 20% Music. I liked the way the CSW sounded, and it's painfully obvious that it's missing
A few i've found on Craiglist nearby:
Boston Accoustics PV600 - $75
Boston Accoustics PV500 - $200
Sony SAW3000 - $100
Klipsch KSW12 - $150
CSW P205 - $200
As you can tell, my budget is pretty small, and my system isnt that needy of a monster sub. (Not until i get that big promotion). So, just looking for something to get me by for now and looking for the best bang for my buck that fits my system.
Or, if there are any other deals out there on the interwebs that would be better than the selection above. Thanks ago so much for the advice!
Current Setup:
Sony SAW3000 - $100
CSW P205 - $200
