AVS › AVS Forum › Audio › Speakers › Another budget matching question
post #1 of 9
Hello all, I hope I put this in the right forum. I recently received the Jamo S426HS3 speaker package for $105.00 which from what I hear is an amazing deal for what you get. I am new to home theater besides a cheapo wal-mart HTIB and would like some help picking a budget receiver and powered subwoofer for the package. It's fine if either are refurbished since it seems most reputable companies carry at least a 1 year warranty on their refurbs. I would like to stay under $400 for both the sub and receiver if at all possible. IF that isn't reasonable just let me know. Thanks for the input!
post #2 of 9
How do they sound? I was looking at them too.
I would look on Craigslist if I were you. I've seen some great deals.
post #3 of 9
Yeah; I can't believe that price! They were selling for around $300 for a long long time (and THAT seemed like a good price...lol).
The Polk PSW505 sub has been going up and down in price, and when it is down it is under $200. That is the best one for a low price I know of. The others you can get for that price are pretty funky.
The Onkyo TX-NR414 is only $230 at Amazon right now...new. If you can fit that in your budget you will have a new unit with warranty, and it is a bargain at that price.
post #4 of 9
post #5 of 9
Thanks for the replies guys. Both these receivers only come with the 2EQ and not the Multi-EQ for the sub correct? I would like to have the multi-eq to tune the sub as well but maybe in my price range that just isn't an option..
post #6 of 9
post #7 of 9
post #8 of 9
Great info afrogt! Can you tell me what is better about the 1612 and 1613 over the 591? Just newer versions?
post #9 of 9
Nevermind I found my answer here. It sounds like there virtually identical.
http://www.avsforum.com/t/1252688/official-denon-avr-391-591-1611-owners-thread
  Back to Forum: Speakers
