I'm in the process of finishing my basement. I finally got the drywall up and coat of primer on the walls. I'm trying to plan out my riser for my home theater seats sitting in the next room. They are 3 recliners together. The closest dimensions for the chairs i found was this image here (http://www.4seating.com/berkline-theater-seats/images/berkline-13175-tangiers-dimensions.jpg). That said, the first row of seats i'm planning on putting directly on the floor. I want to build a riser just behind them for the second row. I have looked at the stickied riser calculator, but because I dont have all the variables decided I cannot get the correct riser height.
Below is a picture of the basement where I plan on putting the screen. Having no experience with projectors / screens my initial plan was to center the screen on this wall and hang curtains on both sides, one to hide the door, the other to just make it symmetrical. But now i'm thinking that approach will only net me a smaller screen - which I'm not sure if it is worth the projector then. So i was thinking if i got around ~106" screen that would still fit on this wall. I would paint the wall and the door black. All AV equipment will be in the room behind the wall. I am assuming the bottom of the screen will be about 24" from the floor. Basement height is 9'
So i'm looking for any recommendations on the following
Edited by dbldown768 - 12/28/12 at 11:26am
- What would a good size screen would you recommend for this wall?
- How far back would you place the first row?
- How far back for the second row?
