AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › blu ray player with component input/output for SD TV
post #1 of 2
hey guys i recently purchased a Samsung BD-E5900 blu ray player and have hooked it up to the tv in the living room which is SD TV. I did purchase a HDMI to Component Converter and some Premium RCA Cables but with the 28AWG cable the reception is not working(I ordered 24AWG to solve the issue as per guidance of Monoprice.com). One thing I was wondering if there any blu ray players out there that are component cable instead of HDMI and has APP access (Netflix, Pandora, Hulu Plus etc..) and also can play DIVX, XVID thru USB? I almost bought a Panasonic but decided on the Samsung instead (the Panasonic did have component so it might have been better) due it being able to play DIVX/XVID thru USB. So if anyone knows any good blu ray players that fit the above criteria I would really appreciate it. Thanks and Happy Holidays.
Sam
post #2 of 2
This topic has come up before...in fact earlier this week. If you go to advance search engine, use component as your search word and use title search only you'll find previous threads on the topic. If you are looking for recent players (there are less and less as time goes on) you'll want to bump an existing thread seeking an update.
This thread is locked
