Hey guys,
I'm hoping you guys can help me decide which to buy.
Both are in the same price range right now $460 for NR809 and $500 for the NR717
I have two questions.
1) Which of these 2 receivers are better overall or would you recommend me buying? I'm leaning towards the 809 because of the Audyssey Multi EQ XT.
2) Can they safely be paired with Energy take classic 5.1? (already bought and I don't plan on using high volumes.)
Thanks in advance,
Ernie
Edited by tjernie - 12/28/12 at 4:24pm
Thanks in advance,
Ernie
