AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › russound bgk1 i Bridge RNET question. can this be connected through a 10/100 switch?
post #1 of 4
or does it require a dedicated cat 5 line? if yes, would using a POE compatible switch make any difference?
thanks
post #2 of 4
Dedicated cat5 line point to point. It is NOT Ethernet.
post #3 of 4
ok, that is what I suspected. does it require a special punch down? thanks for the reply
post #4 of 4
Nope - straight through wiring following the same pattern...
  Back to Forum: Home A/V Distribution
