I decided on building my own dual 15 in. ported subs. This will be the first build I've ever done. I need a lot of help and advice from those of you who have done this before. I think I settled on a driver. It's a MCM 15in. pro loudspeaker rated at 98db which is good right?
Here's the link to the driver - http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-55-2983-/55-2983
I think the max box I can build is 18w x 24h x 20d. Does that sound big enough? also I wanted to go with a dual front ported design under the driver, maybe dual 4in. ports?
Please give me some advice and help if you can because I'm stuck in a rut right now.
Thanks, Jack
Thanks, Jack
Anything would be an upgrade. What do you guys recommend or use for amps on your subs?
