Originally Posted by
studioholic55
Would the ep400 for about $250 due the trick?
If you do the 27hz box the EP4000 is all you need (30hz HPF). If you go with a 20hz tune you will need a different HPF. With the 27hz box you could actually dump 2000 watts from a single bridged ep4000 into each sub without bottoming it (might melt the driver though). With the 20hz tune a single ep4000 channel at 650 watts is a perfect match.
studioholic55
I don't have a svs to sell... and the f20s look way to large for my room. I think Jay's idea is the way I'm headed, basically a copy of the rythmik FV15 in a way. No matter how it turns out I know it will blow away the 2 8's I'm running currently. Could I take those 8's and stick them under or behind the couch for added bass or while that ruin the sound?
You can incorporate the 8"s, not sure which model they are? Obviously they wont be able to keep up at full output, but smoothing the response at lower levels is possible.
