AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung ES8000 best picture settings?
post #1 of 3
At the risk of repeating something that has already been asked and solved I am wondering what the best settings are for this TV, mainly for films and Xbox.
I really like the TV but want to know if I am getting the best out of it, I know these things are subjective but playing FIFA for example there is a lot of blur because of the speed and I was wondering if this could be reduced.
Also can you only edit the default picture settings i.e. Standard, Dynamic, Natural and Film or can you set up and save your own...seems like you should be able to.
So long story short, what are the best settings for film and xbox.
post #2 of 3
Have you checked te owner's thread? Any user settings would be posted there.
S~
post #3 of 3
I hadn't but I will now.
Cheers.
