AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Pioneer Elite SC-65/SC-1527-K Owners Thread.
Official Pioneer Elite SC-65/SC-1527-K Owners Thread. - Page 13
post #361 of 371
Originally Posted by ss9001 View Post
I'd have to look at the block diagram in a service manual I have for the SC-57 & do give you my interpretation of the circuit paths. the 57 has similar design topology. when I get a chance today or tonight, I'll take a look.
are you not getting 5.1 out and checking or asking before you try it?
Oh, don't bother trying to figure that out. I don't think it would work for me, anyhow, to restrict inputs to just the optical inputs. I was just curious.
I was thinking about ordering Turtle Beach XP400 Dolby surround headphones which take a 5.1 digital optical input, and it would have been convenient for me to just take that from the AVR's digital output. I guess I'll have to either get a toslink switch (since my output devices have unused toslink outputs) or an hdmi audio extractor to get a toslink signal out of one of the AVR's hdmi outputs.
Added: Since the AVR doesn't ordinarily pass audio to its hdmi outputs, I'm going to get a toslink switch to feed the headphones.
Edited by GregLee - 3/19/14 at 11:59am
post #362 of 371
I did buy XP400 Turtle Beach headphones -- they were on sale at Amazon for $130. I gave up on the idea of using my Pioneer to supply them with optical digital input, as advised above, and I did instead buy a toslink switch, on Amazon it's "ViewHD SPDIF | TOSLINK Digital Optical Audio Connector (Matrix 4x2)", for $50.
Since I'm bypassing the Pioneer AVR entirely for the headphones, this is off-topic, and I'm keeping it short.
It all seems to be working, basically, except that the base unit for the headphones won't accept some DD ("Master Audio") from my blu-ray player, and the headphones sound rather muffled, compared to the AVR with my speakers. Not so good with music. The headphones do a nice job with surround effects in TV movies, though. The wireless feature works fine.
post #363 of 371
Hi guys, I just snagged a SC 65 for a great price. I have an SC-05 as well that I will retire to my secondary system (still love that receiver).
I was wondering, can you set it to upscale everything to 1080P *unless* it's already 1080P, and in that case, just pass it through?
Or is my only option if I want 1080P passthrough to set everything to passthrough?
post #364 of 371
Hello,
I've just got a new sc-65 on the week-end to replace my old vsx-1018,
everything hooked up, runs fine so far,
connected 7.1 speakers, again all runs fine.
On the back of the receiver it says: "caution speaker impedance 4 ohms" on front height and wide
my question is: can i hook up some older JBL 50 watts 8ohms speaker for front height?
are they going to hold up or blow up?
The rest of the set-up has 125-150 watts speakers connected, i just wanted to re-use these older speakers.
btw I'm running my fronts Polk rti10's on a pre-out NAD amp to alleviate the load on the sc-65.
Also i was wondering if i connect another set to front wide as well as having front height will they all play ?
receiver is 9.2 but connections for 11.2, i'm a bit confused here.
Any help here would be greatly appreciated.
thank you
post #365 of 371
should be fine just make sure in the settings of the reciever set them to small speakers , also if im not mestaken you can change the Oms also in the speaker settings
post #366 of 371
Thank you very much
post #367 of 371
No, the receiver won't do front wides and front heights at the same time (at least if you have all 11 connected up and enabled). Having 11 speakers connected just gives you some choice about which 9 speakers to use. It can't be more than 9 and may well be only 7, depending on what sound mode you've set the receiver to. I think it's true that the Dolby Digital modes only do 7. Neo:X can do 9.
post #368 of 371
I hope someone can help. My SC-65 is having remote/network issues. I hit the NET button and can cycle through the network functions but cannot go up/down on the remote to select anything. In addition I get server error messages on internet radio/sirius/pandora. This happens on the stock remote and a universal. If I reset to factory settings will I have to re-program my remote/hdmi settings/network settings all over again?
Anyone else have this issue?
post #369 of 371
Hi again, when I power off the receiver the message zone 2 on appears. How do I remove this? Also, just added a Martin Logan sub whose manual says I should customize the subs frequency range through the receiver but I can't seem to find the page to set the subs range.hanks
post #370 of 371
I figured out that I had turned on multi zone accidentally. Sorry for the unnecessary post
post #371 of 371
Two problems I'm currently having with my sc-65, cbl-sat hdmi output quit working ( now using bdr-dvr). I get a pop in my speakers when I hit ff along with a super high pitch sound , like it's some type of ground fault, if I unplug the unit it goes away. Now when I turn the unit on sometimes I get no sound, I change the channel & sometimes in get sound & sometimes I don't, unplugging will usually reset but sometimes I have to do it a couple of times. Any ideas ?? I'm in California & never had these problems with the oink yo I had before.
