Hello all, i don't post much but have learned a bit from browsing this site.
After a long day of working at a job I hate I go home to my modest home theater room and waste a few hours before I have to wake up a repeat the tedium that is my life. My room is 12ft by 12ft and I currently have a Mitsubishi WD-60C8 that is the display for my gaming PC, HTPC, and PS3. I like the set very much, its not as good as my old RPCRT but it plays nice with my computer and supports more resolutions. The rainbow effect is a tad annoying and the response time isn't as good as a CRT or plasma but when I bought it it beat everything in its price range. The set has almost 7000 hours on it now and I'm worried the bulb will burn out soon. I've heard that the DLP sets are prone to getting white dots over time. So before I go spend money on a new bulb I was considering a new set.
I can't see myself going down in screen size. I was considering getting a projector but I was worried about the noise from it being a few feet from my head.would be distracting. I'd like a plasma but fear of burn in. LCD TVs look pretty good now a days but are they really my best option?
So I'm not really sure which direction to go towards, should i just replace my bulb and cross my fingers? Save a little money by putting the bulb money towards a new set since the DLP is doomed to failure at some point? I don't really have an exact budget but id like to keep it under $2k,but the closer to $1k the better.
