AVS › AVS Forum › Classifieds › Display Devices › Sony KDL-46HX850 3-D 46" LED 3D Flat Panel Screen HDTV 1080p 3D
For Sale: Sony KDL-46HX850 3-D 46" LED 3D Flat Panel Screen HDTV 1080p 3D
post #1 of 1
$1,595 (USD) or Best Offer
send a PM to take the next step.
For Sale:
Will Ship To: Nowhere -- local only
Brand New Sealed box. Never opened. Shall carry manufacturer complete coverage.
Detailed item info
Description
The Sony HX850 is a 46-inch 3D television, delivering sharp and clear images with a 1080-pixel resolution. The Motionflow XR 960 technology of this LED Sony HDTV facilitates smooth display of fast-moving images, providing a realistic experience while watching movies and sports broadcasts. The Sony HX850 with an X-Reality Pro Engine increases the detailing in images and scenes. With Wi-Fi and DLNA connectivity, this LCD Sony HDTV allows you to stream loads of movies and music from Netflix, Pandora, and more. Supporting Dolby Digital technology, this 3D television helps you to watch movies with a crystal clear audio playback. The HDMI ports in this Sony HX850 let you connect compatible devices and watch movies with remarkable clarity.
Product Identifiers
Brand Sony
Model KDL-46HX850
MPN KDL-46HX850, KDL46HX850
UPC 027242838512
Key Features
TV Type Flat-Panel
Display Technology LED LCD
Screen Size 46"
Definition HDTV
Aspect Ratio 16:9
Resolution 1080p
Display Resolution 1920 x 1080 pixels
3D Technology Full 3D
WiFi Connection Built-in WiFi
Smart TV Features Downloadable Apps, Internet Browsing
Technical Features
Refresh Rate 240 Hz
Built-in Tuner ATSC, NTSC, QAM
Supported Resolutions 1080p (HDTV)
Power
On Mode Power 61.1 W
Sleep Mode Power 0.1 W
Connectivity
Front Input Connectors Audio (RCA) x 1, HDMI x 2, USB Port
Rear Input Connectors Audio (RCA) x 2, Component x 1, Composite x 2
Audio Features
Number Of Speakers 3
Speaker Power 3 x 10 Watt
Audio Type Virtual Surround
Subwoofer With Subwoofer
Dimensions
Height 1.38 in.
Width 42.38 in.
Depth 25.2 in.
Weight 36.6 lbs
Miscellaneous
Parental Control With Parental Control
Room Type Commercial Space, Living Room
Remote Control Type (originally supplied by manufacturer) Standard
Exterior Color Black
Additional Features 3D-ready, Built-in WiFi, DLNA Certified, Headphone Jack, Internet Apps and Widgets
  Back to Forum: Display Devices
