AVS › AVS Forum › Display Devices › Display Calibration › Images to access from NAS to calibrate projector from Dune ?
post #1 of 4
I am just getting into calibration of my projector in my home theater. I have the DVE HD basics blu-ray to set up my blu-ray player but I have just purchased a Dune HD player and want to calibrate my second input on the projector for this player. Is there some .jpeg's or images I can download to my NAS so I can access them from my Dune player and calibrate? I have the filters from the DVE BASIC blu-ray. Maybe they can be used with some of those calibration images.?
thanks in advance.
post #2 of 4
I am not familiar with the Dune, but would assume these will work.
AVS HD709 (.mp4 files)
Gamut Calibration Disk (.mkv or .mp4 files)
post #3 of 4
Thank you very much. Looks like I have much reading to do. I assume there will be files I can download and stream from my NAS to Dune on those links. It was like reading a different language while I briefly skimmed the links smile.gif
Are those a comprehensive list for anything I would need to do to get 90% there calibration wise?
post #4 of 4
Yes, both the links have files that you can stream. Since you are not working with a meter, I would recommend downloading the AVS HD709 .mp4 version - it has patterns for all settings that can be made without a meter. You will only need a small subset of the patterns, since much of the content is for meter based calibration.
Read the Patterns Manual before you start - if you've used DVE, you should not have any trouble with the AVS patterns. http://dl.dropbox.com/u/8968806/Patterns-Manual.pdf
