I have had my VTF-15 in a down firing position for about 2 months already and it smoothed out ALL of the ear pressure i was getting at high levels when watching movies after calibrating with Audyssey. I like the down firing position so much better that i have not moved it for the last two months and it is staying there!
In my 17x24 theater the improvements are...
ALL ear pressure during movies and music is gone
Even MORE feel since all of the pressure waves are hitting the floor!!!
The bass is tighter even in Q 0,7...which is nice.
Hits harder and deeper than before.
I think that the reason i was getting the ear pressure with the regular recomended settings for the VTF-15 is that my theater is all solid wood including ceiling and floor....no leakage...maybe just too much energy being fired at the center of the room. This may not be your cup of tea...but in my room i am a down firing subwoofer guy for sure!!!
Btw..before this i also tinkered with lying the sub side ways and spinning the sub in all directions with the driver facing away etc. Hands down the BEST way was the down firing position...it just hits SO much harder with no ear pressure at all. And oh yea, i also tried it with the driver facing the ceiling...not so good
All of a sudden they see two 50 inch towers hung up on the wall on both sides of the projection screen right in front of their faces along with a center channel. When watching a movie in total darkness or even with moderate light all you should see is the movie/screen not the speakers or the audio equipment lights!
They end up looking a lot like the PA monitors you see hanging at churches and concerts. But if you have a dedicated theater that is black, then they also would blend in without being noticed that much. The trade off is worth it imo. I used to hang the old monster CRT projectors and know how to reinforce a ceiling properly to hang audio and video equipment. In fact i used to sleep right under 150 lb. projector for about 10 years until the lightweights came in to take their place to retire them. Every night i when i was lying in bed i would look straight up at that 30 x 25 block of metal and say to myself "trust in your work".
