Just bought a house. Building a home theater in the basement. I want to soundproof this as properly as I can: clips, two layers of drywall, Green Glue, etc.
I have a few obstacles, but this one is particularly frustrating. The basement has low a ceiling, and has a support beam just after the entrance that I already have to duck under to get into the room.
Currently, the beam is at about my forehead level. It's a nuisance to duck under it, but I can live with it. However, if I have to put full soundproofing around this beam, that will drop the height another couple of inches, and will bring it to the level of my nose. That is unacceptably low.
Moving the beam is not an option. Too complex, too expensive.
I'm willing to sacrifice some soundproofing performance to maintain the current height, or close to it. How important is it to soundproof this beam? It's obviously very heavy, but it's also directly connected to the framing of the house. I don't imagine that many sounds would get through it, but vibrations could be problematic. If I watch a loud, bassy action movie, how annoyed is my wife going to be upstairs?
One contractor recommended that I put the sheetrock, glue, etc only on the sides of the beam. He wants to line the bottom with a material called IsoWalk, that he says will help absord some of the vibrations, at least enough that I can get away with it. I can't find much information about this material. Is it snake oil?
Am I overthinking this? Is it really not as big a concern as I've made it out to be?
What other options do I have that will spare me from having to lower the height of this beam any further than it already is?
Thanks in advance.
Edited by Josh Z - 12/30/12 at 7:29pm
Thanks in advance.
? I guess it depends on where you live to some degree.
