i have loosely placed 3.5 inch R13 insulation inside my sonotube...which can be seen below...this seems a bit excessive...keep in mind this is only 14" diameter sonotube...
will i be okay with the R13 or should i look into egg crate foam...
i believe there is a difference between open cell and closed cell...i believe closed cell will take away from the internal volume of the enclosure...i imagine i do not want this...can someone tell me which of the two is best and how do i know whether i am buying open or closed cell...
