AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › JBL Venue sub 12 amplifier replacement
post #1 of 6
My JBL Venue Sub 12 amplifier is fried. How can I replace the amp? I do not want a replacement from JBL as I have heard a lot of bad reviews on JBL subwoofer power amps. The speaker is fine, but is this sub worth fixing or should I just throw it away and get a new one?
Edited by ondrums - 12/29/12 at 7:07pm
post #2 of 6
Consider replacement plate amps from Parts Express and OAudio. I have two PE plate amps, one of which was used as a replacement on a JBL subwoofer. You will likely need to do some cutting and pasting to get the amp to fit. I pasted 2"x4"s in a rectangular shape to the back of my subwoofer and screwed the PE plate amp into it.
post #3 of 6
Thanks wwinkler! I think I can make the modifications to the JBL sub. I will call Parts Express and Oaudio for the right amp for it. I am glad to hear I am not the only one with this problem!smile.gif
post #4 of 6
I have a JBL Venue Sub 12 I could sell you...I just upgraded from this recently but the shipping probably would not be worth it...
post #5 of 6
Thank you walke108. I am afraid I do not trust JBL since I have heard some bad reviews of this specific subwoofer model'
post #6 of 6
Thank you walke108. I am afraid I do not trust JBL since I have heard some bad reviews of this specific subwoofer model's amp failure. And you are right, shipping would be cost prohibitive. Thank you for your offer!
