AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Is xt32 worth 300$!
Is xt32 worth 300$!
post #1 of 14
Hi everyone. I am stuck between the onkyo 809 (457.00) and the onkyo 818 (779.00) I really want the xt32 audyssey but is it really worth the extra $$?
post #2 of 14
To me, yes. It equalizes the sub(s) better and can optimize two subs separately.
post #3 of 14
post #4 of 14
Thanks guys!
post #5 of 14
The 818's version of XT32 lacks SubEQ HT and isn't able to optimize two subs separately, it will only do one. To the OP yes it's worth the extra $.
post #6 of 14
S it can't do duals but does eq the one sub? And does so better than just st?
post #7 of 14
Yes it equalizes's one sub and yes it is better than no EQ. However if you have 2 subs or plan to get a second sub in the near future then XT32+SubEQ is worth it.
Otherwise just get XT32 because if you decide to add another sub or get a new pair of subs say in 3+ years there will be a cheaper better receiver or maybe "XT64" for example by then.
Edited by FroggyTaco - 12/30/12 at 2:01pm
post #8 of 14
I'm sorry damn auto correct. I meant does the sub eq with xt32 eq it better than the sub eq in audyssey xt?
post #9 of 14
Also yes and potentially "4x" better.
See Link: Audessy Comparison Link
post #10 of 14
no I had the 818 sold it because I still don't like audyssey st32 more than just uneq' d sound in my untreated room.
post #11 of 14
I'm very happy with my Denon 4311 and XT32. I owned several Onkyos with XT and XT32 is well worth the additional cost IMO.
Bill
post #12 of 14
I have a deno 3311 which has audessey xt and also an onkyo with audessey 2eq and honestly i have to say i dont noticed any difference at all. I ran audessey on both receivers using same Speakers, same sub, same room and for me audessey is just "excellent on papers" but in real life are pretty much the same. Cant say nothing about xt32;
On the Onkyo the sub is tighter than the denon and on the onkyo I can hear better details from surrounds than with the denon!!
post #13 of 14
I appreciate the responses! I ended up grabbing the 809 with XT because it was now a 450$ difference in price. I notivce a BIG difference with the XT from multiEQ. I am sure I would hear a difference with xt32, but I would rather put that 400 to an external amp or Oppo blu-ray
post #14 of 14
tongue.gif I bought Archaea's 818 because I wanted to go from XT to XT32. Yes, it makes a difference. $300 worth of difference??? That I couldn't tell you.
