I searched this forum but didn't find the answer to my problem. I have an SA 8300HD DVR hooked up to my TV via HDMI. Everywhere it says that you need to press the GUIDE and INFO buttons at the same time to get into the setup menu, and I believe I have done it that way before as well, but via component cables. Will the setup menu display over the HDMI output? I believe the component output on the DVR or the input on my plasma went bad (not sure which) as the picture became discolored (like one of the 3 cables was disconnected). I then just hooked up an HDMI cable and the picture is now fine. I want to get into the setup menu again now, but it will not display. Not sure if I am not pressing the right buttons, or if it just won't show up over the HDMI output. Or, has Comcast messed with the software/firmware and disabled the ability to get into the setup menu? Anyone have any ideas?
AVS › AVS Forum › HDTV › HDTV Recorders › SA 8300HD DVR (Comcast in Mpls area) - can't get into setup menu
AVS Top Picks
post #2 of 6
12/30/12 at 2:19pm
post #4 of 6
1/1/13 at 2:08pm
post #6 of 6
5/21/13 at 9:47pm
AVS Top Picks
