AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Connect Yamaha RX-V773 Receiver to HDTV, Cable Box, Blue Ray and DVD Recorder
post #1 of 3
I have connected the above devices the following way but somehow Blueray player and DVD Recorder connection doesn't work:
Samsung LED TV - MUN55B6000VF
INPUT - HDMI 1 (DVI) AND RECEIVER OUTPUT - HDMI 1 ARC
DIGITAL AUDIO OUT (OPTICAL) TO RECEIVER INPUT OPTICAL (TV) AV4
Yamaha AV Receiver - RX-V773
OUTPUT - HDMI 1 ARC AND TV INPUT - HDMI 1 (DVI)
INPUT - HDMI 1 (BD/DVD) AND BLUERAY PLAYER HDMI OUTPUT
INPUT HDMI 2 AND CABLE/SATELLITE RECEIVER OUTPUT- HDMI
INPUT OPTICAL (TV) AV4 TO TV OUTPUT DIGITAL AUDIO (OPTICAL)
Samsung Blue Ray Home Theatre - HT-BD1255
OUTPUT HDMI AND RECEIVER INPUT- HDMI 1 (BD/DVD)
Bell TV Cable/Satellite Receiver 9241
OUTPUT HDMI AND RECEIVER INPUT- HDMI 2
SATELLITE IN COXIAL CABLES
Sony DVD Recorder - RDR GX-300
OUTPUT Component Cables to Receiver INPUT AV1
Digital OUT Optical to Receiver INPUT AV1 Optical
I have 5.1 Speakers but somehow INPUT for Subwover cable doesn't seems to work. Can someone advise what is the correct INPUT for Yamaha RX-V773 receiver?
Your help and assistance will be greatly appreciated.
Many Thanks.
post #2 of 3
Isn't the Samsung ht-bd1255 a home theater in a box? It's not meant to connect to a real receiver, it's an all in one solution.
Anyway, I can't find any images as to how the back of that Samsung subwoofer looks, so I don't know how to connect it to your Yamaha receiver. I'm assuming you've connected the other speakers to the Yamaha and not the Samsung.
post #3 of 3
Yes you are correct it is a Samsung home theater in a box.
Due to Samsung has limited number of HDMI and other inputs/outputs, I end up buying Yamaha RX-V773. By the way FR FL Center RR RL speakers working fine except Subower.
I will try to get an image of rear of Subower and post it tomorrow.
Thanks for your response.
