AVS › AVS Forum › Audio › DIY Speakers and Subs › Porting speakers to the front or the rear?
post #1 of 4
Just wondering what type of difference this might make? It obviously assumes where in the room you plan to place the speakers, but assuming away from the rear wall about a foot, does it make much of a difference either way?
post #2 of 4
None. Rear placement is usually employed when it's desirable to keep the cabinet front dimensions as small as possible.
post #3 of 4
Apparently more than you'd think.
I had the same question in my mind a couple days ago and found this:
http://techtalk.parts-express.com/showthread.php?228020-front-or-rear-port
edit with respect to BFM who apparently clicked the submit button just before I did: The link above has to do with leakage of higher frequencies out the port. I'm sure actual performance of the port does not change.
post #4 of 4
Funny enough I've been contemplating the same. I'm very interested in a 15" SEOs build, but the vented baffle is just a couple inches too high to fit under my screen as the center. For this reason I've been thinking of either doing rear port or front slot port.
