AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › DIY Constant Height › What is the most gain on AT Screen
post #1 of 8
I'm planning to do a 140" diagonal cinemascope AT screen. I'm planning to use it with either the pannasonic 8000u or the mitsu hc7800, do I need to have an AT screen with a gain. I would like to know if I can do a DIY AT screen with a 1.4 gain. Is that possible? Thanks. I don't want to go into the details of the building because I'm couple of month away from my ht build where I start building the screen.
post #2 of 8
You wont find a AT screen with 1.4 gain, highest Ive ever seen is 1.2 but most are lower. You will not fill a 140" screen with the 8000 in best mode.
post #3 of 8
You mean that is not going to be bright? What is the highest that I can go with an AT screen?
post #4 of 8
It will be bright if you dont care what the colour looks like, "best mode" will not be bright enough, you will have to use one of the video type settings. The highest gain AT screen is a 1.2
post #5 of 8
So how big can I go with a cinemascope or 16:9? What projector with lens memory will fill a 140" cinemascope?
post #6 of 8
You can go to 140" scope with a AT screen if you use one of the new JVCs. Im using the new X95 with a 150" AT scope screen but I dont use the lens memory I use an anamorphic lens. Check out my HT in my signature, you will see the screen.
post #7 of 8
Here is a formula that you can use:
Achieve at least 16 foot lamberts brightness in calibrated, 'Cinema' mode assuming you have a completely light controlled room (higher brightness if this is not the case). This is calculated as 'lumens/screen area (sq. ft.) x screen gain. You will need to find what the calibrated brightness of the projector is in lumens. For the Panny, 'The PT-AE8000 measured 602 lumens calibrated in "best" mode' according to ProjectorReviews.com
So, your maximum screen size will be: 602/16 x 1.2 (assuming the highest gain screen possible) = 45.2 sq. ft. or a 122" diagonal (16:9)
If you use an anamorphic lens for a 2.37 screen, you will get away with a 124" width by 52.3" high (134.6" diagonal) (This factors a 10% brightness loss due to the lens, although good lenses lose much less light).
You may also factor in bulb dimming over time, so your screen sizes will be even smaller.
post #8 of 8
  Back to Forum: DIY Constant Height
