post #1 of 1
First off, hello, everyone! First post.
I was wondering what your thoughts are on whether or not the Pioneer VSX-521k receiver is powerful enough to effectively drive the Mirage OMD-15 floor standers as fronts in a 5.1 set up.
I know it probably isn't idea power output, however, I just was looking for affirmation that this AVR won't be clipping or otherwise severely under-powering these somewhat more hungry speakers than I usually run- I'm slowly upgrading my speaker system piece by piece.
Just want to make sure I won't be putting the speakers at risk due to underpowering them or overloading the receiver, since they are rated as 6ohm nominal (4ohm min) and slated for 25-250 watts.
Also, would there be any issues with the fact the fronts would be 6ohms resistance, while the CC and surrounds are all 8ohm?
Thanks for any input!
