Hi all,
I am hoping for some help with a long standing issue that I have.
I have the following equipment in my home cinema and configuration is below:
AMP: Denon AVR1910
BLU-RAY: Panasonic DMP-BDT310
Projector: Optoma HD20
Denon Amp has HDMI switching and all equipment is plugged in here. Only 1x HDMI out to 2 sources so i use a Cablesson SVP-12S HDMI Splitter.
When watching a BLU-RAY only, the projector seems to lose signal at around 1hr50min (always the best bit) of a movie. The projector cycles through the inputs until it sees the signal again and it happens again around 1min later.
If I feed the projector directly from the AMP I don't get the issue, only when using the splitter. I also only get the issue from the BLU-RAY player: XBOX, SKY, APPLE TV are all ok.
I have so far tried the following:
1. Swapped the splitter with a friend and have the same issue.
2. Swapped BLU-RAY
3. Plugged HDMI (15Meter Van Den HUL) directly into AMP and this resolves the problem.
I have another friend with they same kind of system who gets the same issue. It seems common to 1080p as another friend with 720p and same config is ok.
So, maybe a booster is required or some config on the BLU-RAY player but Im not sure where to go next. Any help would be appreciated.
Thanks alot,
Jim.
AMP: Denon AVR1910
2. Swapped BLU-RAY
Thanks alot,
Jim.
