Hello all,
Sorry if this has already been posted. I've been up practically 2 days straight trying to get the XBMC working correctly on my XIOS. If any anyone has any links with step by step instructions I would appreciate it.
When I try to play a movie. I get a popup (External Player Active: Click OK when playback has ended) but nothing happens from there the movie selected does not play
Not sure what info you need but. Her's some info:
XBMC frodo 12.0 beta2 Git:20121204
Screenr resolution 1280x720@60 Hz -full screen (31.0fps)
OP: Linux 2.6.3.4-gff8be95.
installed MX Player Pro:
playercorefactory.xml
- - - com.mxtech.videoplayer.pro true -
advancedsettings.xml
- - 0 45 - 3 1000 - true 48 500 560 256 2
BTW I've also reset to factory and tried the firmwares on Pivos forum. Git it working with the forum guys help. but was still unhappy with the no DTS-HD-MA. So if here is abolutely no way to get the XIOS working with DTHD MA. then I gues I'm SOL
Edited by ltworf13 - 12/31/12 at 8:49am
