Hi all,
I am looking to buy a sub in $400-$500 price range and narrowed down the choices to HSU VTF-1 series and SVS SB1000/PB1000.
This sub will augment an existing in wall 5 speaker system (3 on the wall behind the screen, 2 on the opposite wall). Speakers came with the house, so not sure what type of speakers they are.
The room is 20x20 with a vaulted ceiling (8 feet going up to 10 feet in the center). The room is carpeted.
We will use the sub mostly for movies though occasionally for music as well. No particular preference for size and/or look
I have looked at other companies (Def Tech, Klipsch etc..) but given the rave reviews on this forum for HSU and SVS, I am leaning more towards these. Would also appreciate your input on whether my coverage is too limited or if I should look at other brands.
Thanks a lot in advance for your advice,
