I will be buying m&k s-150 speakers with a b&K component. I am wondering what you all use for thx sound for speaker cable? I was thinking about the monster thx 14/2 stranded. i have also heard to buy something with a solid wire. I just wonder what wire everyone is using for their thx cert. systems. I have the opportunity to buy a solid speaker cable at 18 awg but not certified. I just am wondering if I should use the stranded or solid. If solid is the best to go where can I get solid for around 60.00 for about 100 ft. I like the audioquest but way to expensive. thanks!
