I would like to get some input on the results I got when running YPAO with my Kipsch RW12 sub. The set up that I have is a Yamaha RX-A710 receiver, Pioneer FS52 Front and CS52 center with SB52s for the surround. I have a Klipsch Rw12d with this as well. When I run setup the results show the distances very close to the actual distances of the speakers (I realize this has to do with timing and not actual distance). The amount of adjustment to the speakers is minimal with the left front and rear at 0 in the rights adjusted be less than dB each. I followed the advice to get the sub-woofer to be within + / - 3 dB and to get that I had to turn the speaker on the sub down to -23 dB, not a big deal we are just setting the amp gain im not really concerned with the number. So I run YPAO and the results are the fronts are set to small, the rears are set to large and the Sub is set with a +2.5 dB level and a crossover point of 120Hz. If I adjusted the sub volume any higher or lower the level was outside if the + / - 3 dB range.
When listening to this configuration the bass is non existent for movies and even in bass heavy music electronic music. I made some changes and set the rear speakers to small and the fronts to large because I like the extra fullness that it adds to the sound. To get a reasonable amount of bass I ended up setting the volume on the sub at -10 as opposed to the -23 that gave me the initial reading and Ii and dropped the crossover to 60Hz. I would be interested to hear any input on the oddball settings that YPAO returned on speaker sizes and sub-woofer level?
I like the sound with the adjustments that I have made to it. I have had this set up for a month or so and have made several trials with YPAO and the various sound settings in my receiver and know that my current set up is the sound that I prefer. Is it normal for the auto set to set sub-woofer levels so low?
