AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Picture Degradation Question
post #1 of 8
I just installed a new 60" panasonic in our main viewing area and moved our 3 yr old TCP50G15 down to the basement. There was a significant degradation of the picture quality after the move. Before, in the main viewing area, it was connected to a pioneer VSX-1019AH-K receiver. The cable ran to the DVR with an hdmi connection between DVR and receiver, and hdmi between receiver and tv. Now in the basement I am just running cable from DVR to tv - no hdmi. Would this explain the degradation?
post #2 of 8
That receiver just passes the video signal through. I have the same setup and whether I go direct or through the AVR it makes no difference. What sort of degradation are seeing? if you are now using component cables, you will not get the same quality as with HDMI, even if you are feeding it the same resolution format from the same DVR.
Ian
post #3 of 8
Ian
Mostly the picture is just kinda blurry or indistinct. Like watching tv on an old cathode ray tube set. Some shadowing (not sure what to call it exactly) around text - eg, letters will have faint shadows of themselves repeating around them.
I'm running an old catv 6 series cable connection from the DVR to the tv - no component cables. I'm wondering if it's the old cable or maybe the comcast box, an older Motorola DCT2224-1661-ACDeck digital cable converter.
post #4 of 8
You need to run either HDMI or component cables from the HD-DVR to your HDTV (assuming it's an HD-DVR).
post #5 of 8
Well the box does not have hdmi or component connections, only composite. So I'm guessing the box is the problem.
post #6 of 8
Definitely the box
post #7 of 8
That must not be an HD box, since you can only get SD resolution from a coax or composite output.
Trade it for an HD box with HDMI and component outputs that support 1080i HD format.
post #8 of 8
I'm getting comcast's "anyroom" service installed next week, so that should solve the problem.
