So here is my current setup:
I have a 1920x1080monitor and a 1080p hdtv hooked up to a 'monoprice' VGA Amplifier Splitter. The HDTV is hooked up via a VGA 75ft cable to that aforementioned splitter. The cable wire goes under the trailer I live in, and back inside.
It works: It allows anything I display on the bedroom monitor to show on the tv in the living room. (That monitor is actually the 2nd monitor..in the bedroom) That would be Windows Media Center and/or Netflix, Pandora, or the web...or just reading documents on a big huge monitor.
The TV reads the signal as 1920x1080@60hz hooked up via VGA... Here are the issues though: The colors are slightly weird: I've tried fiddling with all the controls I can. There are 'Phase/Clock/Brightness/Contrast... auto adjust...' Advanced PC settings..... Sometimes the Yellows are just way too yellow, and the green is way too green! I've tried fiddling with the 'Color Temperature' but that doesn't help. On my TV there are no controls for actual Color settings?!?! If you look really close to the TV, you can see the pixels are shimming... Also the mouse cursor has a shadow, as other things do.
btw: My TV is a TCL L42FHDE30 42-Inch
At one point I converted the signal to HDMI. However the converter I had did not work in 1080p mode, but only in 720p mode. I believe it was a defective product. I sent that product back. I didn't think to check the colors at the time. Also I believe the contrast ratio is not as good as watching 1080i cable tv as well. Note: I do not have a blue-ray player to really see a true 1080p experience. But I can see a 1080i picture from cable. The defective product I had was a "Etekcity Video VGA to HDMI 1080P Converter/Adapter"
Questions/solutions:
Would it be worth it to buy another converter to go from VGA to HDMI? Note: I'm stuck with the basically buried VGA 75ft cable... So I would need to convert that to HDMI. I would just need a better converter than the one above.
Is the length of the cable the problem, and that is why my colors are weird? (and not fixable...) or because of the cheap tv, you know, it was black friday deal...
