AVS › AVS Forum › 3D Central › 3D Displays › Benq W1070 144Hz Compatible DLP-LINK 3D Glasses
Benq W1070 144Hz Compatible DLP-LINK 3D Glasses - Page 24
post #691 of 800
Originally Posted by knobert View Post
anyone try these ones yet? www.3dwear.ca?
These look like some of the cheaper brands from China. I don't even think they are DLP glasses.
post #692 of 800
It would be difficult for anyone to have tried them as they are listed as 'Coming Soon'
post #693 of 800
After my BenQ W1070 projector purchase in January, I finally splurged on a set of Dimensional Optics 3D DLP Link glasses. I have 30 days to try them, before they are keepers. For those who have compared the Dimensional Optics glasses to others, can you pls let me know of your thoughts regarding pros/cons, apart from price?
Also, I watched a couple of 3D movies -- Hugo and Wreck It Ralph -- which were pretty immersive, but were slightly uncomfortable to watch in 3D. I wonder if you all can advise if I need to change any settings on the projector to reduce this discomfort? My seating position is roughly 8-10 ft from the screen.
post #694 of 800
Sorry they looked similar to the sain sonic type
post #695 of 800
If they are in any way similar to Sainsonic glasses I for one would stay well clear .... but there is no proof that they are similar, just a word of warning.
post #696 of 800
EStar America ESG601 are down to $34.99. I wonder whether they're better than the 3DTV for $29.
http://www.amazon.com/EStar-America-ESG601-Link-Glasses/dp/B00CRN3D98
post #697 of 800
Are these the 3DTV Corp glasses everyone talking about?
I see they have lots of glasses. Really confused
post #698 of 800
these are good also
post #699 of 800
There are two, the DLPRL (rechargeable) and DLP2 (battery). Here are the links from the manufacturer. Amazon also sells them.
http://ahugq.vcfpq.servertrust.com/product_p/dlprl.htm
http://ahugq.vcfpq.servertrust.com/product_p/dlp2.htm
post #700 of 800
I got the ones in the first link right after Christmas. Seemed pretty good. Some of the 3D we tried out from Netflix was just bad, but others it is really good. nitro circus looked the best. black looked pretty black to me and they only went out of sync when i looked away from the screen for a bit, otherwise no issues with losing sync.
I was apprehensive ordering direct from them because their website has a horrible domain name and doesn't look very good, but the glasses showed up and so far so good. We'll see if they continue to hold a charge over time or develop any other issues.
Thank you to rwestley for the recommendation.
post #701 of 800
where do you guys buy cheap sainsonic 3D glasses? ebay, amazon of directly form sainsonic.com?
post #702 of 800
Originally Posted by farleyville View Post
I'll add a +1 on this thread for the Dimensional Optics glasses...
http://www.dimensionaloptics.com/Product.aspx?l=00010001000100100001&p=A1S01323
Unboxed them last night (ordered four pairs for the family for Christmas), charged them up and tried them last night on 3 different movies. I have no experience with any other glasses with the W1070, but I will say that these are comfortable, show no red flash that I can see, and just work. I was trying to make them lose sync by walking out of the room staring at lights, etc.. but as soon as I stepped back in front of the screen within 1/2 a second they were synced back up.
Very pleased. Tried it out with IMAX Under the Sea, and everything looked stunning. I spent $169 on 4 pairs after coupon, which is a little bit more than the other glasses on amazon / ebay, but given that they are rechargeable, fit perfectly, come with a nice case, and I ordered direct from the company makes it feel worth it to me. Before I made my order I called and talked with someone at the company and they were extremely helpful, explained how the glasses fit on his 7 year old granddaughter etc.... If you are on the fence, you will be happy with these. But, I can't speak for the other options.
Hi Farleyville, I just ordered some of these glasses for my W1070 and was wondering if they had an option to only sync one eye's view at a time. My family should be fine, but we have a couple of family friends who cannot see 3D because of vision issues. However, they could potentially watch with us if the glasses can only show one eye's view (if you know what I mean). Do you know if that is possible with those? Or should I just not invite them to 3D movies at my house wink.gif?
post #703 of 800
As far as I know they do not, only have 1 button to turn them on and it syncs both eyes. But I doubt they give this option as 3D only works with both eyes synced. If you close one eye, the stereoscopic effect is lost.
post #704 of 800
Yeah, they can't see stereoscopic images in real life (one is missing an eye, the other can't focus out of both at the same time), so I was hoping that there might be a way for them to watch with us. But if not that'll just mean they get invited over for 2D movies and we won't mention 3D.
post #705 of 800
I don't see any problem with your friends using the glasses - they will have to use them to see one clear image with the good eye. If it helps, you can block one lens somehow - use a rubber band to cover it with cotton or plastic cutout.
post #706 of 800
This is what I'd already concluded would have to be done. Oh well. Thanks for your help on this: I do appreciate it!
post #707 of 800
Hi, from memory one brand, I believe it is TrueDepth, have an option, via a push button, to select one 'eye view' or the other. It was principally for use with multiplayer games where one player had his/her glasses set to one 'eye' and the other set to the opposite 'eye'. I think that they were version 3.5 and the option had to be requested (no additional cost). Do some research on this, it was discussed earlier in this thread from memory.
There are also a number of videos on YouTube that show you how to 'modify' 3D glasses to be 'single view'. Search for 'Make Active 3D Dual Play Glasses' or similar. You could buy very cheap Sainsonic glasses and modify them using the instructions, this would be the cheapest option. It depends on how 'handy you are.
Here is an example of the DIY videos.
http://www.youtube.com/watch?v=hLf0DTl6o-I
Edited by OZReddog - 1/4/14 at 6:45pm
post #708 of 800
post #709 of 800
Hi Everyone,
Just wanted to make a note about Dimensional Optics customer service: phenomenal! I've been waiting for them to get glasses back in stock and ship them to me. Amazon said they'd be back in stock on 1/6: obviously it's later than that, so I sent an email to ask. Steve (Dimensional Optics' president) replied within an hour or so and said he'd upgrade me to expedited shipping at no charge and that he'd let me know as soon as they came in (they were on route from their factory). He then sent another email an hour or so after that to update me that they'd be getting their shipment tomorrow and he'd give me tracking via Amazon as soon as they were shipped. All in all, a few hours passed and I got several email updates from the President of the company. I'm very impressed. Hopefully I'll have more good things to say once they arrive and I try them out.
post #710 of 800
3ACTIVE glasses are $50 (Amazon)
3DTV CORP glasses are $30 (eBay)
For those who have both, why should I pay $20 more for the 3ACTIVE glasses?
post #711 of 800
My two cents:
I just bought on Amazon a couple of Cinemax glasses and they seem to the job perfectly.
I watched a bit of The Hobbit and they didn't lose sync, and they block the red tint as well. I'm living in Europe (Spain) and the 3DTVcorp and other ones were too expensive for me because of the shipping costs, I tried these, and I'm very happy with the result. I'm doing it via the PC, with a bluray drive and arcsoft total media theater. For some reason Corel WinDVD doesn't recognize the projector as 3D (even if for other 3D media like SBS files it works).
I've got a question but I don't know if this is the right place to do it, anyway, here it goes:
I have an AMD graphics card, can I do 3D gaming with the W1070 without an nVidia set? I read that there's something called "tridef" but I think that's software that converts 2D to 3D, so no real, native 3D.
Thank you all!!
post #712 of 800
Just took the plunge on some of the cheapest 144hz glasses available anywhere. Here's the Ebay link - they cost me $11.85 shipped which I believe is a new low for 144hz glasses period.
http://www.ebay.com/itm/144Hz-3D-DLP-Link-Active-Glasses-for-BenQ-Optoma-Acer-Viewsonic-LG-Projector-/360815797983?pt=US_Video_Glasses&hash=item54024c26df
Contrast is only listed at 750:1 compared to my beloved bulky 2x 3DTV Corps from Amazon which are 1200:1 contrast. But these cheap ones will be for an occasional guest (unless they completely suck). Some have said that certain glasses block red flash better than others - while I've also heard that they either block red flash or they don't and that there's no middle ground. Could be that these will not appear to do such a great job at it anyway since there are no sides to block the red light in your peripheral vision
I'll report back and let you guys know if they are halfway decent or not. From the design it looks like they just bought a bunch of discontinued Samsung glasses and repurposed them
Edited by gamermwm - 1/16/14 at 1:23am
post #713 of 800
Interesting. Please let us know how good or bad they are ;-)
post #714 of 800
I looked at the feedback for the seller and searched for "dlp-link" and all were positive. Look forward to your review as well!
post #715 of 800
Thanks, I have ordered a couple to try or perhaps convert to two player gaming devices. Great price!!
post #716 of 800
post #717 of 800
They are the same ones I posted a pic of in a post above. Haven't gotten them in yet, and they are pretty new so I don't think anyone else has tried them out yet. They are being re-branded and sold by different names/manufacturers
post #718 of 800
Actually, two are different in at least one aspect. The first one (in the picture) uses a CR2025 Button Cell Battery which is disposable (as do the ones direct from Sainsonic). The Amazon ones say they are rechargeable (but they are not!!) and two to three times the price.
So, we must assume that they are all the same, except for the name/logo printed on the top on the bridge (the first has 'DLP' and the other two have 'Gonbes') and they are on opposite sides, and of course the prices.
Edit: After a small amount of research, they are manufactured by Gonbes Technology CO.,Ltd. Shenzhen, Guangdong, China and are model number G15-DLP
Edited by OZReddog - 1/19/14 at 6:48pm
post #719 of 800
post #720 of 800
[img]http://www.independentproducts.co.uk/Benq_3D_glasses_big.jpg[/img]
P/N :5J.JOT14.011
Dear members,
                      Can the following Benq glasses use on W1070 ?? I can't seem to sync with any 3D bluray movies... Quite a noob on 3D ..hope to get some advise :)
Jack
  Back to Forum: 3D Displays
