post #1 of 1
The lamp fan has failed. It is a Sanyo-Denki part number 9AH0912M4D04. Apparently this part was manufactured solely for Mits and Sanyo can not give me any specs on the fan. I found somewhere on the net that someone said Sanyo part # 9AH0912M4D05 would work. So I bought fan 9AH0912M4D05 installed it and the tv runs for about 30 seconds max and then I am getting error code 42 (Lamp Fan Failed). I had installed the new fan to suck the air from the lamp and blow it out the side of the tv, is this correct or did I install it backwards. Or is the problem with the fan model number that I am using.
MOD please delete this post. I posted in the wrong section
Edited by guppy1 - 12/31/12 at 5:32pm
