I have a few question about the TC Sounds Epic 12
1) Does the TC Sound Epic 12 have any inductance control measures in place? TC's spec sheet has parameters for a 3 element Le model. They suggest a response moderately affected by inductance. I realize it's not a lot of dB in the 10 to 100Hz range, is it accurate or not?
2) What is the right xmax to use when modeling the Epic 12? The spec sheet says geometric number is 18.1mm, but the 70% BL number is 22.9mm. Do you really want to push the voice coil out of the gap?
