AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Truck Sub System
Truck Sub System
post #1 of 2
Hi I am considering buying the following:
https://www.sonicelectronix.com/item_43129_Hifonics-GLX1400.1D.html
2 https://www.sonicelectronix.com/item_38117_Earthquake-Sound-TNT-12S.html
https://www.sonicelectronix.com/item_62719_Ground-Shaker-ST-2-12-BLACK.html
And I was wondering if it is all compatible before I purchase
post #2 of 2
It looks like they should all work together.
I find it unlikely that these subs have a 2" Xmax which is usally measured as a 1 way stroke. Looking at the magnet, my guess is the subs have around a 12-13mm xmax and that would be pushing it. Either way, the subs will supply a 2 ohm load to that amp for around 1000 watts available.
Box looks good on paper. should be fine
  Back to Forum: Car Audio, Video, and Nav
