I just tried to hook up my ps3 via hdmi to my denon avr 1612 and i am not getting any picture or audio. On the other hand when i go from PS3 to direct HDTV hdmi port it works perfectly and easily. Any ideas on what is wrong here?
AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Denon AVR 1612 not working with PS3
Featured Stories
Topics Discussed
Related Forum Threads
- (SOLD)BEST PRICE!!!FREE SHIPPING!! DENON AVR 1612 IN EXCELLENT CONDITION. Last post on 6/8/13 at 4:12pm in Audio Gear
- DENON AVR 1612 EXCELLENT CONDITION. Last post on 6/8/13 at 5:37am in Audio Gear
- Denon AVR-1612 any Alternative to Airplay? Last post on 4/12/13 at 11:26am in Receivers, Amps, and Processors
- denon avr-1612 Last post on 2/27/13 at 7:28pm in Receivers, Amps, and Processors
- Denon 1612 AVR No Audio via TV Speakers on ARC Last post on 2/21/13 at 12:26pm in Receivers, Amps, and Processors
Gear mentioned in this thread:
- dooodstevenn
- Trader Feedback: 0
- offline
- 5 Posts. Joined 8/2012
- Thumbs Up: 10
- Select All Posts By This User
I have also tried an optical cable hijacked from my other speaker bar set up. changed the settings in the PS3 to go optical but no luck...are there differences in optical cables? maybe i was using a wrong cable? Right now i have it set up so that picture goes directly to the HDTV through HDMI but audio is routed to the receiver using good ol fashion yellow and white cables so i could atleast use 2 speakers and bass.
post #3 of 8
12/31/12 at 7:52pm
- Mikazaru
- offline
- 1,648 Posts. Joined 9/2004
- Thumbs Up: 17
Hdmi handshake problems unfortunately. My PS3 has been very problematic in this regard whenever I take it out of my system. You can try power-cycling your equipment or differerent hdmi cables, but that has never worked for me. What has worked is swapping out my PS3 for my 360 (seems to re-establish the connection) and back again. If you don't have a 360, I imagine any hdmi source component might do the trick. If that doesn't work, you might have to use component cables (the first time it happened to me, I dug out my old PS2 component cables which are compatible with the PS3), but I know this is a less than ideal solution.
You can also try getting into the PS3 Recovery Menu ( hold power button until it beeps twice) and restarting the system.
post #4 of 8
12/31/12 at 8:07pm
- Mikazaru
- offline
- Thumbs Up: 17
post #5 of 8
1/1/13 at 8:31am
- futurecode
- victoria concordia crescit
- offline
- 426 Posts. Joined 5/2007
- Thumbs Up: 15
Check to see if you have any hdmi processing enabled in the 1612, that might be the issue.
post #6 of 8
1/1/13 at 1:09pm
- gregzoll
- offline
- 1,996 Posts. Joined 6/2009
- Thumbs Up: 25
The 1612 does not have any kind of hdmi processing that can be changed by the end user. It is the basic of their units. Suggest the OP check to make sure that they have the right input selected for the PS3.For the OP, if you leave the hdmi cable connected, then connect a Blu-Ray player or catv box, turn the 1612 back on, same with the hdset, do you get a picture & audio from that device?
post #7 of 8
1/4/13 at 6:03am
- Netko350Z
- You got TRUMPED!!
- offline
- 407 Posts. Joined 8/2007
- Thumbs Up: 10
post #8 of 8
1/14/13 at 1:59pm
- Crisis.VT
- offline
- 2 Posts. Joined 12/2007
- Thumbs Up: 10
I'm having similar issues OP:
My PS3 is connected via HDMI (an AmazonBasics 1.4 [max1.4 hdmi 2m]) to my Denon AVR-1612.
When the AVR is connected to my monitor, a Samsung T260HD, I have no issues.
However, when I connected the receiver to two different new HDTVs (a LG 42CS560 and a Samsung UN40EH6000), both had HDCP handshake issues. In both cases, the issue disappeared when the PS3 was directly connected to the TV (via HDMI). I tried the following to fix the issue:
Like you, I am very frustrated by this, particularly since direct connecting the PS3 means I need to use optical audio out, limiting my output options, and I have to take extra steps when using different devices. If anyone has additional suggestions, I would be most appreciative.
- Reset the PS3's video settings (start holding down the power button for ~5-seconds, until you hear a beep)
- Restricted the HDMI output to 1080p only (unchecking 1080i and 720p)
- Swapped out the cable for other known good HDMI cables
- Set audio output to Optical instead of HDMI
Back to Forum: PlayStation Area
- Denon AVR 1612 not working with PS3
Currently, there are 1685 Active Users
(374 Members and 1311 Guests)
Recent Discussions
- › Guide to Building a HTPC, Workstation and Server 28 seconds ago
- › Hot Off The Press: The Latest TV News and Information 49 seconds ago
- › The East Coast TV's Experiment 52 seconds ago
- › Official Samsung UNXXF7100 Owners Thread 1 minute ago
- › The official SeymourAV center stage screen thread! 1 minute ago
- › America's Got Talent, season 8 (2013) 1 minute ago
- › F8500.. OR .. ZT60 ????? 1 minute ago
- › SEOS 12/AE TD12M Project 2 minutes ago
- › Help choosing center speaker 2 minutes ago
- › 100k speakers vs 1k speakers! 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
