Thank you very much beforehand.
Featured Stories
Topics Discussed
- brandEmotiva
- itemEmotiva Xpa 5 5 Channel Power Amplifier
- brandParasound
Related Forum Threads
- Marantz AV7005 and Emotiva XPA-5 Last post on Yesterday at 12:45 pm in Audio Gear
- Emotiva XPA-5 Last post on 5/5/13 at 5:53am in Audio Gear
- Emotiva amp connected to my Yamaha AVR, would this help any? Last post on 4/25/13 at 12:09pm in Receivers, Amps, and Processors
- Need a 5ch Amplifier - Parasound Halo A52, Emotiva XPA-5, or something else? Last post on 4/15/13 at 3:57am in Receivers, Amps, and Processors
- Emotiva XPA-5 Last post on 4/14/13 at 8:03am in Audio Gear
Related Reviews
Emotiva XPA-5 or Parasound A51 ?
Gear mentioned in this thread:
- 4DHD
- Trader Feedback: 0
- JBL/Revel/Parasound
- offline
- 5,377 Posts. Joined 8/2004
- Select All Posts By This User
- Theresa
- offline
- 2,291 Posts. Joined 11/2010
Don't believe marketing hype like "High Bias A/AB" without double blind tests to prove it is actually something that can be heard. The money spent on a Parasound amp is almost always better spent on room treatments and speakers. All "AB" amps operate in class "A" up to a certain point as do all competently designed amps. The Emotiva amps all have vanishingly low distortion which can be seen by the independent tests they publish on their site.
- kbarnes701
- offline
- 10,411 Posts. Joined 1/2008
+1. What does "High Bias A/AB" even mean?
There is also the issue of "The A51 will produce a better soundstage" too. How on earth does an amp "produce a soundstage"? Where has that come from? If it is from the marketing literature of the amp manufacturer, then I would be highly skeptical about anything else in that literature too as the idea that an amp can influence the soundstage in any way is pure BS*. Just sayin'...
And, of course, you are 100% right about spending the money saved on better speakers and/or treatments. That's where the biggest SQ improvements will be heard - not in some alleged differences between amps.
EDIT:
*Just for the sake of completeness it is perhaps worth mentioning the Bob Carver patented 'Dimensional Sound Producing Apparatus' where Carver does claim to be able to 'enhance' stereo imaging by deliberately introducing a delayed and equalised signal in both (stereo) speakers. AFAIK this technology has never found its way into a modern SS amplifier and is, in any case, a deliberate distortion of the input signal. I can't recall the precise details of how it worked, but google will find "Dimensional Sound Producing Apparatus" I am sure, for anyone interested in reading more.
Edited by kbarnes701 - 1/1/13 at 2:00pm
- kbarnes701
- offline
Modern solid state amps, when working within their design parameters (eg not clipping) have been shown in numerous blind ABX tests to be indistinguishable in sound quality. If the amps under consideration are powerful enough to drive your speakers to the desired levels, without clipping, then the cheapest is the one to go for (assuming decent design / build quality, which the Emo amps have in spades).
Here is a page of links to various blind tests:
http://www.head-fi.org/t/486598/testing-audiophile-claims-and-myths
- David Susilo
- Trader Feedback: +6
- Industry Insider
- offline
- 7,935 Posts. Joined 8/2002
- Jinjuku
- offline
- 1,996 Posts. Joined 3/2007
Biased in that it may operate class A for the first 5 watts instead of first 2 watts.
Class A's technical merit is that while in Class A you aren't building the wave form with two banks of transistors which it not designed properly can introduce cross over distortion. On the Stereo imaging and soundstage side as long as your channel crosstalk is they will both image well.
I ran Parasound, I ran Adcom. Surprisingly enough I now run 'Pro-Audio' gear: Crown. My XLS402D is a better amp than my two Parasound HCA-1000's. Where the Parasounds were a bit noisy the Crown is Ink-black.
- David Susilo
- Industry Insider
- offline
- jima4a
- offline
- 800 Posts. Joined 6/2011
- jima4a
- offline
If music is a big part, tough to beat the Halo series.
- Jinjuku
- offline
All I know is three years running I offered up my Parasounds to anyone that wanted to come by and blind tell me if they were listening to them or my Crown on my Statements. It was a 10 flips of the coin. Take a guess how many people I had take me up on that offer.
The XLS402D is one competent AMP IMO. Check out the New amp is making me grin from ear to ear thread
Also Home Theater Equipment has a Crown XLS DriveCore thread (Where Parasound was also removed to make room for Crown).
Edited by Jinjuku - 1/2/13 at 8:22am
and they replaced them no charge and paid for the Fed Ex charges. The Amp drives my Martin Logans wiithout a problem as my last power amp went into fault with
the ML.
I cannot recommend them more..plus telephone tech support is easy, complete and always available.
- kbarnes701
- offline
Considering I'm in Canada, how difficult is it should I need to fix the power amp? will Emotiva pay for shipping both ways? I'm asking this because to ship the Emotiva registered with tracking and signature-required will cost me near half the price of the power amp itself.
I am in the UK. For warranty Emo will only pay one way IIRC. But they will work with your local repair shop to help diagnose the problem and then ship parts directly to them. I have never had a problem with any of my 4 Emo amps and I am of the view that if the amps work OK for the first week they will probably be OK for years. Amps are fairly simple devices so the local shop should have no problem fixing a faulty unit, using Emo's spares.
- Emotiva XPA-5 or Parasound A51 ?
Recent Discussions
- › Help Replacing Infinity RS5 50 seconds ago
- › 2013 Formula 1 in HD 52 seconds ago
- › The New Master List of BASS in Movies with Frequency Charts 2 minutes ago
- › Do I really need Expensive Speakers for Home Theater? 2 minutes ago
- › Sherwood R-972 User Thread 3 minutes ago
- › Shermer Theater (looking for HVAC/Electric/soffit advice) 3 minutes ago
- › Energy Owners Thread 3 minutes ago
- › Russound DMS-3.1 Digital Media Streamer question 4 minutes ago
- › B&W CCM-65 Ceiling Speakers for Front Heights? 4 minutes ago
- › Official JTR speaker thread 5 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
