AVS › AVS Forum › Audio › Receivers, Amps, and Processors › pioneer sc 35 or denon 2312
post #1 of 2
I need help - which one is a better AV receiver - it'll be primarily for movies - def tech speakers x5 +subwoofer - epson 8500 ub hc. thanks!
post #2 of 2
Are you getting both for the same price? I think the SC-35 is a higher end receiver, it list for $1600 and uses the ICE amps which have gotten good reviews. It also has preamp outputs in case you need to add an external amp later for more power.
