I bought these speakers used a couple of weeks ago for my HT gaming room. With the exception of vibration, they filled the job fantastically for gaming, as I figured the vibration was coming from the walls and room treatments would cure that. Well, now I know the source of the vibration, its coming from the rear port, the plate amp and probably the sub as well! Is there any fix for this? The subs look to be in good shape and the screws are tight on it as well as the amp.
