Hey Folks,
Another yawn inspiring setup question from a novice. I'll try to be as concise as possible. Thanks in advance for your insight and assistance.
Here is my current Speaker Setup:
Fronts/Center - Polk RM201 x 3
Surrounds - Polk RM101s x 2
Subwoofer - Velodyne CT120
Reciever - Onkyo TX-SR605
I've Run Audyssey II but the whole shebang just sounds off. The fronts and center are set to full band and the sub is just overpowering unless i turn it down to near 0. Here's what i'd like to know:
On Receiver:
- Fronts and Center Crossover? 40-200Hz
- Surrounds Crossover: 40-200
- LFE Crossover: 80-120
On Sub:
- LPF Crossover: 40-120
- HPF Crossover: 80 or 120
- Direct or In Sub Crossover?
- Phase Control: 0 or 180
I've got the distances setup correctly and i'm pretty sure i have the sub location in the best spot available. Just need some help tweaking these puppies.
Thanks again in advance and please let me know if you need more info from me about my setup, listening habits, additional equipment or specs on the above.
Thank you!
Edited by phorts - 1/1/13 at 1:33pm
On Receiver:
On Sub:
Thank you!
