I want to take my old projector down which was controlled via serial and replace it with a Samsung UN65ES8000. From a automation point of view, I only see IR as a option. Then it was suggested that CEC might be a option. The AVR in the rack (50 feet away)will provide the audio and all source switching. So all I need to run to this location is one HDMI cable, one ethernet cable and a extension for a IR emmiter (if I use IR). All I really need to do is turn it on/off. So how does CEC work and is it a good option if I only want it for power?
