AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sharp LC-60LE640U or the Sony KDL-60EX645?
post #1 of 5
Title says it all. Which TV is better?
post #2 of 5
Don't know about the Sony but own 60LE640U and really like it.
post #3 of 5
Bumping this thread as I would like to know too..
I can get either for $100 difference, worth it to jump for the Sony?
post #4 of 5
I doubt it. The panels in both sets are probably both manufactured by Sharp anyway (Sony TVs used Sharp panels as recently as last year, as I recall).
I don't know if PAL or 1080i/50hz compatibility is a concern, but Sharp has historically supported 1080i/50, as well as PAL video on all inputs (including composite), although many Sony panels unofficially support it on HDMI and Component (but not composite).
post #5 of 5
If you are going to use the tuner, I would lean towards the Sony. Sharp's QAM decoding can be a bit finicky about how it displays some sub channels. PSID info can be set to, say, 32.8 but the Sharp may display it on 32.6.
Also have had issues when a 32", 46", and a 52" Sharp display of the same series would tune a particular HD cable channel, but the 40" would not. Exact same cable drop. Disassembly revealed different tuner boards from size to size, although all were LE700 series from a few years ago.
That being said, with over 60 of them installed in a 3 story campus recreational facility, there has only been two complete failures to date after 3+ years and 16 hours a day of operation. If you are only going to use outside sources, the Sharp is a safe bet if you like the picture.
