AVS › AVS Forum › Audio › DIY Speakers and Subs › Anyone ever try the Quad-THT Coffee Table?
post #1 of 6
In my searching for a way to blend in a TH in my awkwardly open 12k cu ft living room, I came across this: http://davidproberts.com/2011/01/24/quad-tht-woofer/
Just wondered if something like that would work well, and could fill that amount of space? I've searched to no avail, but has anyone tried something like this?
post #2 of 6
I'm not so sure that design would work. Doesn't look right at all to me.
It would be a WHOLE lot less trouble just to build a table with multiple drivers in either a sealed or vented alignment.
post #3 of 6
It came to him in a dream? More like a nightmare. Nothing about that design makes any sense, while using the name Table Tuba is copyright infringement.
post #4 of 6
post #5 of 6
Plus, anything in the center of the room is typically the worst possible place for sub placement.
Not to mention that 4 of them together would be a massive table!
post #6 of 6
Altec made a coffee table sub years ago. Not a horn though. It was the LF-2.
