AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo HT-R510 Issue
Onkyo HT-R510 Issue
post #1 of 3
I am having an issue with my Onkyo HT-R510 receiver. After resetting and then unplugging the receiver from the power outlet all 6.1 speakers work. After a couple minutes the music just stops and would only work when i click "direct". Only the two front speakers work and the others are mute. I toy around with the settings and nothing turns the other speakers on. I get frustrated and do the steps all over again by resetting and then unplugging and it works again on all 6 speakers right away without changing anything. Has anyone ever had this issue or can help? Thank you very much.
post #2 of 3
i replaced some of my components on the center channel as they were blown out.. that solved my problems. In fact you could borrow some good components from the 6th channel as I never use it myself. LOL amazon just had the 2011 onkyo nr809 for $445.00 and now its $645. Thats my solution for this old receiver.
post #3 of 3
Thanks a lot pal. As with the parts, I dont know anything about ti so i guess its time for a new receiver.
