There is one question about factors thet contributes to perceived 3d quality and I’ll put it this way :
1- for a given screen size , when moving a projector within focus range (mini-maxi ) to keep this same screen size, what effect does this have on perceived 3d depth and pop.
2- Does it matter if you are sitting in between the projector and the screen versus behind the projector
3- What is the 3d percieved difference (depth pop) for the same screen size between 2 projectors with different focus capabilities (ex short throw w1070 versus normal throw projector ( ex w7000)
4- Do all projectors have the paralax adjustment like the new panasonic and does this have any effect on depth ? ?
